Need help diagnosing bad vibration
Posted: Sun Apr 21, 2013 8:36 am
Hey all,
My van has recently acquired a bad vibration/banging thing when driving. Basically, when I am driving I get a regular clunking sound but when I ease off the throttle the clunking and vibration gets worse - even at speed - and the van sort of jerks along as if it has a warped brake disc. When slowing to a stop, the jerking is like something grabs then lets go at regular intervals.
The vibration (for lack of a better description) is at regular intervals which would indicate to me that it is cause by something that rotates. It slows as the van slows and speeds up as the van speeds up. I don't feel it in the steering wheel which makes me think it is either in the driveline or rear brakes. I haven't had any hot brake smell. Front calipers were recently replaced at CVI. A quick check of the temperature of the hubs after driving indicated the driver side rear was a little warmer than the other three sooo... maybe a brake problem?
The only reason for doubting the brake problem is the vibration gets quite severe when feathering the throttle (letting off the throttle but not all the way) while driving.
Has anyone had any similar experiences. Any suggestions? I am on the Sunshine Coast so it's not as simple as taking it to CVI for diagnosis...
Thanks for any input... will check back later today.
Cheers!
Ian
Cheers!
Ian
