Have you seen this?
Posted: Mon Jul 15, 2013 10:12 pm
by Rattlenbang
Delica glow plug relay control module. I'm working on my system as my van was returned to me with the glow circuit totally dead.
For what it does, this is ridiculously overcomplicated. Seriously. Early 90's technology wasn't that backwards. You could build a robot that could take over the world with little more than that. I wonder if it was actually designed for a completely different application that Mitsubishi picked up by the shipping container cheap.
Re: Have you seen this?
Posted: Tue Jul 16, 2013 10:12 am
by MardyDelica
yes, Its common problem with this one as time goes by those resistor or components parts fail.
new is expensive. you can just do push botton with relay same as old diesel component and will works fine.
cheers
Posted: Tue Jul 16, 2013 10:59 am
by thedjjack
when mine goes I am thinking fitting a Mercedes OM617 controller ....dirt cheap and bullet proof...
Please feel free to steal this idea and figure it out....should be real easy to fit...and I think glow times are close...
Posted: Tue Jul 16, 2013 11:12 am
by MardyDelica
yes, that will work just don't know the system when the time cut off delay on that module
its just a matter or trying to figure diff type of module which one works
cheers
Posted: Tue Jul 16, 2013 1:31 pm
by nxski
If you need a new one, I'm selling a fully refurbished one for $200 (I put in a manual switch instead because the plugs I have are the wrong resistance).
Posted: Tue Jul 16, 2013 1:39 pm
by Rattlenbang
At this point I'm looking for a circuit diagram for this kind of controller. The diagram I found on this site uses a single connector while mine has the two as shown in the above picture. I want to trace a few voltages before I start trying to fix this. I used to be an electronics tech so fixing it should be an option, but first things first.
Posted: Wed Jul 17, 2013 1:45 pm
by bbisset
http://www.ebay.ca/itm/Ford-diesel-glow ... 0485301931
Works awesome. Just make sure you use the 11V plugs, not the 7V quick-start version.
Posted: Wed Jul 17, 2013 3:28 pm
by Rattlenbang
Ok, but why not use existing relay and glow plugs? I know about burning them out, so as long as you only zap them a short time. I don't think mine ever came on more than 3 seconds when the auto circuit was working.
Posted: Wed Jul 17, 2013 5:54 pm
Somewhere on this site is a post regarding how a member had an issue with his ECU and had it successfully repaired at a television repair shop for a nominal fee and a material cost of a $1.37 resistor. Also in the Engine Electrical manual starting on page 16-39, albeit a Pajero system, is a system check. Maybe worth looking at ~ hope this helps.
Posted: Fri Jul 19, 2013 7:44 am
by Rattlenbang
I might get around to troubleshooting the module, but for now I just popped in a manual switch. Works like a hot damn. What's interesting to not is that while it only takes a couple of secs of preheat to light her up instantly, if you don't give her a few jabs of glow plug once she starts, she stumbles and blows smoke for a few moments. A few pokes of the switch and it clears up and smooths out.
