Lift points on Delica's?
Posted: Thu Dec 26, 2013 10:54 am
by Mr. Flibble
I am fortunate enough to have access to a hydraulic lift.
Unfortunately, I don't know where the appropriate lift points would be on my van. I don't think that the arms can reach all the way from the rear axle to the front, that is just to far being a LWB.
what points would you guys use if you have four lift points on a hydraulic lift?
Re: Lift points on Delica's?
Posted: Thu Dec 26, 2013 1:17 pm
by Yokohama
What type of lift are you using? If it is the typical 2-post, floor mounted type, then it should not be a problem for the arms to reach.
If the arms will reach any of the front mounts (the ones for service work, not the rocker panel, tire changing jack locations); as long as they are in approved locations and the vehicle is balanced, it
should be fine. L400 jacking locations:
Posted: Thu Dec 26, 2013 1:54 pm
by Mr. Flibble
Yokohama wrote:What type of lift are you using? If it is the typical 2-post, floor mounted type, then it should not be a problem for the arms to reach.
Yes, 2 post floor mounted type.
This is the perfect infographic!
Exactly what I needed to figure out where to mount the points!
