AV Stage operation info
patriceboivin
Member's Photo Album: http://www.delica.ca/Photos/index.php?cat=23122
Vehicle: Mitsubishi Delica L400 Super Exceed
Post by patriceboivin »
Hi,
Is there an owner's manual for the AV Stage in the Royal Exceed?
I contacted Mitsubishi Motors Canada and they were not helpful at all. :o
Strange behaviour that, if they were thinking long-term I would expect them to be more enthusiastic about their own company's products.
Big-Bird
Vehicle: 96 PE8W Spacegear
Re: AV Stage operation info
Post by Big-Bird »
Do a search on Delica Kareoke Machines.
Green1, a Deli owner on this forum has figured out how the rear AV system works.
He had this to say in a 2010 post on the forum
Think of the karaoke unit as a remote control for the main unit, if you adjust the volume on it, it simply adjusts the volume on the main unit. If you change inputs on it, it simply changes the input on the main unit. It doesn't do much of anything on it's own, it simply allows you to control the main head unit while sitting in the back seat. it also happens to have aux inputs and headphone outputs on it, but basically they are just wired from it to the main unit and controlled from either it or the head unit.
The closest analogy I can come up with is those little IR remote controls that ship with most modern stereos, except hard wired and capable of more functions. This is also why it doesn't work with after market stereos, it would be like removing your kenwood stereo, and expecting it's IR remote control to still control your new sony stereo which doesn't even have an IR receiver, sure it MIGHT be possible to hack together some form of adapter, but it won't simply "work" because the unit is just a remote control, it doesn't DO anything of it's own.
Big-Bird
Post by Big-Bird »
Found this post about the AV Stage.
http://www.mdocuk.co.uk/forums/viewtopi ... 1a9740de26
