rebuilding my Mitsu 4d55 with Hyundai parts??
Posted: Mon Mar 10, 2014 4:56 am
Hi all, I've got an 83' 4d55 that lost compression due to worn rings. I tore the engine down a couple months ago and took it to a machine shop for inspection. Boring .30 over will clean the liners up, and the crank is in good shape so I guess I'm sticking with standard size bearings.
I'm now living in Ulaanbaatar, Mongolia for a few months, and Hyundai Porters, Gallopers, Starex vans, etc etc are a dime a dozen here! They all have, from what I understand, my engine in them. I plan on buying my parts here and taking them home to rebuild my engine in a few months. I visited several Korean parts suppliers and they can get me everything I need to rebuild those Hyundai engines, but I've got a few questions first....
Are the Korean parts up to par with Japanese? Can anyone recommend a few Korean brands that have a good reputation? They are cheaper then the Japanese parts I found online, but can I trust them more then the Chinese parts??
Second question is what parts are not compatible with my 4d55?? Here's my "needs" list so far, am I able to just buy these parts for the Hyundai engine and use them to rebuild my Mitsu engine? Are there any parts I'm missing that are necessary for the rebuild (aside from the head/top end, turbo, and injection pump)?
.30 over pistons and rings
main bearings
balance shaft bearings
connecting rod bushings
connecting rod bearings
gasket set
timing belt
oil pump gear
water pump
Thanks all!
main bearings
gasket set
timing belt
oil pump gear
water pump
Thanks all!
