L400 LWB trailer hitch, front receiver
patriceboivin
Member's Photo Album: http://www.delica.ca/Photos/index.php?cat=23122
Vehicle: Mitsubishi Delica L400 Super Exceed
Post by patriceboivin »
I wandered into Work & Play here and asked them if they can install hitches for imported vehicles.
After some back and forth, it told them the Delica might be similar to the Montero but they had "Montero Sport" and "Montero".
Cost for those: $280
However he told me they don't do welds ( :shock: ) because of liability issues.
Apparently if they weld anything and something is wrong, they might be liable.
Odd because years ago when we rented a U-Haul trailer for a 1997 Honda Odyssey they welded a hitch to it without hesitating.
This must be like U-Haul refusing to rent trailers to people who own Ford Explorers "because of potential legal costs".
I found some hitches in Japan but they are expensive even without shipping.
e.g. http://www.loft-japan.co.jp/hitchmember ... /g356.html
or
http://www.sun-auto.co.jp/products/line ... ishi-.html
Probably neither of these would ship to North America anyway, the weight must be too high and the cost way too high.
I know someone who has been a welder for 20+ years here, built steel bridges etc., maybe I will ask him.
Of course I could wander into U-Haul but am not sure what I'll get; last time it only took them about 15 minutes to weld a hitch onto my 4-door Odyssey.
As for the front hitch/receiver for a small plough, maybe my friend can help -- Work & Play didn't seem to do anything custom, they just bolt on "kits" they receive from suppliers.
And of course their web sites and software all use the same pre-made drop-down lists for vehicle years / makes / models.
You know the lists... "1994" / "Mitsubishi" / <no useful model exists>.
Feds
Re: L400 LWB trailer hitch, front receiver
Post by Feds »
You are pretty much stuck to making your own. There are downloads on the Auzzie site that will give you the gist of building your own hitch. I ended up buying a used class iv/v hitch, cutting off the end plates, and welding on new ones (made of flat plate and angle) to fit the van. It attaches through existing holes as well as through the shipping tie downs. I've pulled as much as 7,000 lbs with it with no trouble.
Find a good fabricator, pay cash, assume all the liability.
The only other option is to get one shipped in from overseas or possibly one of the BC shops.
