Rear sunroof L300 Aero P25W troubles
Posted: Sun Sep 14, 2014 8:02 am
Hey guys,
On my new to me 89 L300 Aero P25W the sunroof in the rear of the van works, but not quite correctly. It will open, but needs a little help at times. Also it will close by always needs help, and even when it is closed I have to push up on the right rear corner, and slide part of the mechanism forward to make sure it stays up in that corner for sealing it with the body seal. It isn't a huge pain as I know what to do to get it closed, but I would like to fix it. I have found that under the "Power Sunroof" script on the control button area there is a manual override that uses a allen wrench to close the roof in case of a dead battery or whatnot.
Does anyone have a break down of the parts on the sunroof? Anyone experience similar issues with the sunroof? If so what was your fix? Any chance I can find parts for this area if need be?
