Hey guys,
I have a fairly rough shaking when i accelerate until i reach speeds around 85km-90km anyone know what may cause this?
Re: Shaking Between 40km-80km
Posted: Thu May 07, 2015 11:14 am
by Big-Bird
If you feel the vibration in the seat and the steering wheel doesn't shake then the issue is in the rear.
If the sterring wheel shakes then the problem is up front.
1) Tire(s): Shifted belt or separation of inner structure, flat spots on the tire(s) or you lost wheel weights and a tire has a heavy spot that makes it shake.
2) A warped brake rotor can do this too in certain conditions.
3) Loose worn suspension parts...ball joints, tie rods etc.
4) Last items to check would be the driveshaft u-joints followed by axle/spindle bearings
