while I have the front end off....
Posted: Mon May 16, 2016 6:37 am
by obeygravity
Will be replacing both of the AC fans on my 98 gasser, and will have most of the front end off to get at them. Suggestions of other things I should do while I'm in there?
Re: while I have the front end off....
Posted: Mon May 16, 2016 2:21 pm
by thelazygreenfox
install a transmission cooler fan (behind the pass side headlight).
MD
Posted: Tue May 17, 2016 8:40 am
by obeygravity
Is that just a plug and play type affair, or do I need to wire in some sort of thermostatically controlled switch? Would the fan be a generic Princess Auto piece, or something a bit more specific? I have had the transmission get hot on me on a couple of long off-road climbs.
Posted: Tue May 17, 2016 2:25 pm
by thelazygreenfox
OG
I didn't get any further than seeing it at the rear of the headlight. My dash warning light came on once on a long 4X4 climb last year but like so many other projects was shelved till you mentioned it. 5 minutes later with a quick lunch break the light went out.
let me know
MD
