LED Headlight
Posted: Sun Jan 13, 2008 11:30 pm
by sasquatch-hunter
8000k LED H3 bulbs
http://www.superbrightleds.com/specs/H3_11-WHP.htm
Way cheaper than HID.
Re: LED Headlight
Posted: Sun Jan 13, 2008 11:40 pm
by Schwa
that won't be enough light for night-time driving, but fine in a DRL situation
Re: LED Headlight
Posted: Mon Jan 14, 2008 3:42 pm
by Green1
their brightest H4 bulb is 40 lummens... that's not headlight brightness... I have a flashlight that puts out 85 lummens... (and a brighter version that does 120)
Re: LED Headlight
Posted: Mon Jan 14, 2008 8:25 pm
by sasquatch-hunter
Probably still have wait for a few years for the technology to catch up.
Re: LED Headlight
Posted: Mon Jan 14, 2008 8:39 pm
by Green1
it's very close actually... said 85 Lumen flashlight is actually LED... (and it's rather bright for a flashlight!) but headlights are still a ways off, though some vehicle manufacturers are toying with them, if you put enough of the ultra-bright ones together you can just about do it... but you pretty much need to design the vehicle around it as it ends up being a lot of LEDs
Re: LED Headlight
Posted: Sat Feb 02, 2008 6:58 pm
by VSM
If your Deli is in need of headlight, the only way to go is HID. I have put it in the my last 2 delicas and you end up with pretty much the same light as a Mercedes. It is an actual Gas filled bulb, with an exciter and balast.
