Since the van is efi, and there is no mechanical connection between pedal and pump.
Is there a potentiometer in the pedal assembly that sends a signal to the pump?, my van hiccups pretty much at a throttle setting that move me at 90kph, 80 kph is fine , and over 95kph is good to just around 90 it hiccups pretty hard. It was like this for a while just not as pronounced.it drive fine otherwise. No real info on this. Any help would be much appreciated
						98 delica 4M40 accelerator pedal issue?
				pembydirt
 - Vehicle: delica chamonix
				Hitomi
 - Vehicle: Mitsubishi Delica
Hi i had the same problem with my l400 S2 and I thought of all these different issues that could be causing it, and in the end, it was my alternator. Something else convinced me to change my alternator, and when I did, the issue disappeared.
Have you checked in the "L400 Dedicated Technical Reference Library/ L400 Shop Manual Downloads"? Look for it on the board index.
