I have access to a free replacement piece in better condition than mine, is it difficult to remove?
Sent from my SM-A520F using Tapatalk
How difficult to remove front clip? (carbon fiber looking piece between headlights)
- Vehicle: Mitsubishi Delica L300 P35W
"Delilah" 91 L300 P35W Exceed
It's held in with plastic clips, almost the same type as on the door linings. They're sealed ("sealed"?) with foam rings, but the foam breaks down over time. You'll need to apply some kind of non-hardening sealant to the new panel's clips.
Simply remove the headlamps and use a long spudger/lever to gently lift the panel away from the steel behind.
