Head lights
Posted: Sat Jan 26, 2008 9:49 am
by mama lou
Hi - We finally got our long awaited van but the high beams don't work. From reading other threads i would say we have new style lights, the outside low beam works but not very bright and the inside big one not at all. Also when i push the high beam lever the dash indicator does not even light up. Anyone know ?
Thanks, Lou
Re: Head lights
Posted: Sat Jan 26, 2008 11:03 am
by EnviroImports.com
did you put any quality bulbs in them?
is the housing loose in the back of the light, its a phillips screw, I know you dident get them from me so I cant say what might be wrong , but I would look at the bulbs and make sure the housing where the actual light bulb is not loose.
hope that helps
Noel
Re: Head lights
Posted: Sat Jan 26, 2008 12:19 pm
by MardyDelica
Hi, what brand you have in your headlight, there is only 2 kind around,
both works, but if you have have a wrong connection it wont work , you need to find somebody who knows how to put the proper DRL to your headlight, i mean knowledge in electrical in cars.
not just by doing yourself if your not used to it. you might have bad connection thats why there not enough power to produce bright light.
the depo brand has the bright light than the other one.
hope this help:
cheers;
