Cam shaft thrust O rings leak?
Posted: Fri Dec 28, 2018 11:36 pm
				Hi folks,
I recently purchased a 1994 Delica, and the speciality mechanic I took it to told me that I had a slight engine oil leak from the "cam shaft thrust O rings" at the back of the engine, and that those seals need to be replaced. I was told this is very common with these vehicles. One speciality mechanic told me it can only be done by dropping the transmission and engine, so as to get access to those o rings, and that it's very labor/time intensive and a very high cost to do the job. Another speciality mechanic told me that they do it with the engine in place, for a fraction of the cost. Then the first mechanic told me that the second mechanic was essentially lying, and that the second mechanic probably only reaches up and spreads silicone over the old seals, crosses their fingers, and tells you it was done.
So I'm looking for some guidance on this...
Has any body done this job themselves?
Does the engine need to be removed?
Can you tell me where to find info on doing this job myself, if it can be?
Any additonal info would be very appreciated, like; is this important to fix, what are these camshaft thrust o rings?
Or even just telling me how to search for this info on this forum would be helpful, as I have tried every combination of the words "Cam shaft, o rings, seals" etc, and can't seem to find the right subject, even though I've been that this is one of the most common issues with these vehicles. So can you advise on how to search for this topic, what words to use?
I'd like to just hear from private owners please, not professional mechanics, so as to not add to the confusion.
much appreciated, I'm thankful to have this community of help.
1994 L400 Delica V6 gas 3000
cheers
cheers
