Squeak when in 4WD
Posted: Fri Apr 25, 2008 8:40 pm
by quadzilla
When I am in 4WD (high or low) I hear a squeak from the left front wheel when driving at low speeds. Any thoughts on what might create such a squeak? Wheel Bearing?
Re: Squeak when in 4WD
Posted: Sun Apr 27, 2008 8:16 pm
by bae146
Probably you cv joint is lacking lubrication. Check your cv boots, ensure they are not cracked or split. You can remove the clamp on the big end of the boot and look inside to see if the grease is dried up.......
Posted: Mon Apr 28, 2008 11:27 pm
by quadzilla
Thanks - I will check it out when I get back home...
