running lights stay on when ignition turned off
Posted: Fri May 16, 2008 9:12 am
by travellin mama
Hello All,
It has happened twice~engine off, lights turned off, running lights stayed on. Both times I had to remove the positive lead to my battery terminal. Has anybody experienced this before? Suggestions welcome.
Re: running lights stay on when ignition turned off
Posted: Fri May 16, 2008 1:28 pm
by after oil
sounds like the DRLs are wired straight to positive and not to powered when key is in on postition.
Posted: Fri May 16, 2008 4:28 pm
by travellin mama
Thanks for your insight. I just removed the fuse from the relay and, voila, problem solved. I don't need no stinkin DRL's. Japanoid says the relay box I'm using, Hamsar, is so crappy they no longer stock them. Replacement cost for something decent~$75.
Posted: Fri May 16, 2008 5:23 pm
by after oil
i got a relay for $10-15 (i cant remember for sure) at napa
Posted: Fri May 16, 2008 11:12 pm
by travellin mama
Oh just when I thought I had things under control...my damn lights stayed on again! So it's not the relay. If my DLR's were wired incorrectly why would they have worked for weeks and now work only intermittently?
Posted: Sat May 17, 2008 8:30 pm
by Schwa
travellin mama wrote:I don't need no stinkin DRL's.
The cops pulled me over because my headlights were off in broad daylight... I'd like to see them doing that to ALL the post 90? 91? vehicles... ha! My fuse was out because they're wired to accessory power, so they're on if I'm just listening to music, and that's not cool.
Posted: Sun May 18, 2008 10:08 am
by travellin mama
Wow, I've never driven anything new enough to have DRL's and had no idea it was a legal requirement on newer vehicles. These headlights have been the bane of my Delica experience right from the start.
