Thanks, Chris
ccautos wrote:These are not the same as Monteros . Monteros use a steering box not a rack and have all differnet ball joints and control arms . Pajeros are the same as Monteros and use almost all of the same steering components . First check is ride height before carrying out the alignment . Once the van is `level` then the angles can be set . We have found inner and outer tie rods wear commonly and also the upper ball joints wear if not regularly greased but rarely have any problems with lower ball joints . Camber and caster readings can be adjusted up and down to make the van drive straight but toe must be set correctly or it will wear tires . When setting up a van to drive straight we often adjust the down to -0.2 degrees but rarely below that or it tends to scrub the edge of the tire . One other thing to check is the upper control arm bushings for wear as this seems to be getting more common .
Nitpick. I believe you are actually referring to castor, not camber. The numbers I have (from Mystery Machine) are:Duke wrote:The reading for the right front camber is -5 degrees, it should be at 3 degrees.
Yup, Hayes was the first manual I looked for, could'nt find one.sounds like the russek manual....
