Power inverter question
Posted: Sat Jun 28, 2008 2:21 pm
by delica 304
I had an idea to install a small sausage compressor in my van, but I would need to convert 12VDC to 110ACV. I know Cambodian Tire sells some power converters, but after hearing how they seem to like to burst into flames, I'm a little leary of those. SO, what other options for power conversion units are there out there??
Re: Power inverter question
Posted: Sat Jun 28, 2008 4:51 pm
by marsgal42
Ask the pros. Around here (Vancouver) that means RP or Polar Battery.
Posted: Sat Jun 28, 2008 5:08 pm
by delicat
Check some of TardisDeli posts or just contact them directly, they are very helpful on the matter. And don't have any commercial interest!
David
Posted: Sat Jun 28, 2008 5:12 pm
If you want the compressor for pumping up tyres then I would recommend the "Eliminator" from Cambodian Tire. If you want the compressor for pumping up your shocks I would recommend talking to "North Shore Off Road" ( http://www.nsor.com ).
The "Eliminator" also has two a/c outputs, a cigarette plug and jumper cables ~ and goes for around $100 ~ $150. Looks a bit like a high tech lunch box.
