Removing rear drum brake cover
Posted: Mon Jun 30, 2008 7:37 pm
by snelson
Really quick question. How do you remove the rear drum brake cover? Is there a special tool?
I have a squeel once in a while and wanted to check it out but couldn't see how to remove the cover......
Steve
Re: Removing rear drum brake cover
Posted: Tue Jul 01, 2008 7:31 am
by monstabishi
hi Steve,once wheel is removed a few gentle taps with a rubber mallet should get it off,unless the hub is badly worn in wich case you may need to back off the self adjuster a couple of turns.......good luck.
MICK.
