Block heater
Posted: Fri Sep 26, 2008 9:33 pm
by robinsherry
hey guys and girls, has any one installed a block heater in there van. If so what kind and how? thanks
Re: Block heater
Posted: Sat Sep 27, 2008 8:50 am
by MardyDelica
Hi, I might have some coming in Block heater,
right now out of stock,
not easy to install this as its very tight spot.
Buzz me later when i recieved the block heater.
cheers;
Re: Block heater
Posted: Sat Sep 27, 2008 5:45 pm
by kb&2dogs
Glen (CC autos) put a block heater in the bushbunny for us. Give him a call.
Re: Block heater
Posted: Mon Sep 29, 2008 6:51 pm
by robinsherry
mardy when do you think you will have some in and how much would they cost, with an install. thanks
Re: Block heater
Posted: Mon Sep 29, 2008 9:04 pm
by MardyDelica
hi, i charge $45 for block heater, with the installation it will be total for $ 200.00 + tax, i am still waiting to order as it will be a big order for me. i inform you guys later.
Re: Block heater
Posted: Sun Oct 05, 2008 6:37 pm
by robinsherry
ok great would like one intalled, and a few other things done let me know when they come in and i will come in to get her all put in
robin
Re: Block heater
Posted: Wed Oct 15, 2008 10:03 am
by EnviroImports.com
I just had a supply of Delica/Pajero Block heaters come in, $39.88, with a 12 month warrantee.
Noel
Re: Block heater
Posted: Thu Oct 16, 2008 4:28 pm
by robinsherry
hey thanks for the response , so are the block heaters or rad hose inserts to keep the coolent wam,
thanks, and are the hard to install , and do you have a picture
thankyou
Re: Block heater
Posted: Thu Oct 16, 2008 4:50 pm
by ccautos
Block heaters are located into the core plug in behind the starter motor . See attached ....
Re: Block heater
Posted: Thu Oct 16, 2008 5:05 pm
by robinsherry
so would it be easy or hard for me to install on my own,?
Re: Block heater
Posted: Thu Oct 16, 2008 8:49 pm
by ccautos
You have to support the engine , remove the left engine mount and starter motor , drain the coolant from the block and then set about removing the core plug . If you have the tools and basic mechanical ability it is a fairly easy job . If you do not have sufficient tools or do not feel confident about it get a professional .
