Radio wiring color code, need help!
Posted: Sun Oct 12, 2008 5:59 pm
by delicat
Hi,
Just trying to install a radio in my wife's Delica and I'm getting frustrated. I got the Mitsu adaptor plugs ready to hook onto the Alpine stereo but:
On the Delica side there's 2 wire box, the large one is for the speaker. No big deal I can figure it out by try and error. But the smaller wire box has 4 wires coming in: a black with blue, a black with red, a gray with blue and a gray with red. Those I want to know where to couple them with the stereo. And none of them seem to have power on them, is it normal?
From what I can tell the radio side has a yellow wire for the battery, a red wire for the ignition, a black for the ground and a orange for illumination. (the other wires I can't care less)
So, any idea which wire goes where?
Thanks,
David
Re: Radio wiring color code, need help!
Posted: Mon Oct 13, 2008 9:24 am
by EnviroImports.com
I go to the local stereo shop, buy the dodge colt,mitsubishi wiring adapter, costs $20 all the wires match up with 2 extras for power antenna and one other orange one i dont remember what it does, but its VERY easy with the adapter kit.
for $20 your pretty likely to get the wiring right, not getting it right and having a fire can just ruin your day
Posted: Mon Oct 13, 2008 5:19 pm
by fostlongstrider
Hi
There is a topic under ICE on the MDOCUK site that gives the ISO colour codes and the Mitsubishi colour codes for all the stereo wiring,I used it to fit a Sony into mine and it all works.
One of those pairs of wires would be for a power antenna,the other pair could be something obscure relative to the particular vehicle you have.
Posted: Mon Oct 13, 2008 8:32 pm
by joostio
I did a search on the engilsh and aussie deli sites and found a post with info regarding the sterio wires. It was greast, told me what mitsi wire goes to what aftermarket sterio wire, sorry I don't have the link. wil try to find it for ya.
http://www.mdocuk.co.uk/forums/viewtopi ... 446f9960fa
try that
Posted: Tue Oct 14, 2008 11:51 am
by delicat
Thanks guys!
Noel, I have the Mitsu Colt kit but the wires aren't the same color as the main harness... hence my question.
David
Posted: Tue Oct 14, 2008 10:26 pm
by TardisDeli
Hi All,
We just got a genuine Delica wiring harness (heartfelt thanks to Glen at CC Autos) with the labels attached to it. Here are the equivalents. There are two parts to the plug, an 8 pin and a 4 pin.
NOTE: Ground is done via the radio chassis to the vehicle body. Ground is negative.
Wiring Harness Mitsubishi Colour Codes for Stereo:
Mitsibushi Colour = Usual North American Stereo Colour = used for:
8 pin plug:
Blue with white stripe = red = 12 volt accesory.
Red with Black stripe = yellow = 12 volt main power.
Green with white stripe and red dots = orange with white stripe = illumination (lighting).
Yellow with green stripe and red dots = green = rear left speaker (postive).
White with red stripe and red dots = white = front left speaker (positive).
Yellow with red stripe and red dots = purple = rear right speaker (positive).
White with blue stripe and red dots = grey = front right speaker (positive).
4 pin plug:
White with blue stripe and red dots = green with black stripe = rear left speaker (negative).
Red with black stripe = white with black stripe = front left speaker (negative).
White with red stripe and red dots = purple with black stripe = rear right speker (negative).
Blue with black stripe and red dots = grey with black stripe = front right speaker (negative).
PM us with a phone number if you need more info. Thanks, Jay.
Posted: Wed Oct 15, 2008 7:25 am
by delicat
Exactly what I was looking for, thanks Jay!
No wonder I couldn't find power as I assumed the 8 pins were for speakers... Never assume!!!
Is there a way we could keep only Jay's part of the post and add it into the FAQ or tech stickies?
David
Posted: Sat Nov 01, 2008 10:08 pm
by chrisbouchard
wow that was awesome!
after installing and checking out each speaker i notice that by adjusting the balance and fade, i cant completely isolate each speaker correctly. the rear right seems to always stay on... maybe just a little quirk in my deli but other than that (and needing to swap out the stock speakers for some new ones) the install is complete!!
Posted: Sun Nov 02, 2008 12:58 pm
by mararmeisto
delicat wrote:Exactly what I was looking for, thanks Jay!
David
Copy and paste the pertinent data into one of the Wikipages. That would be the best way to keep all that wonderful information.
