Page 1 of 2
Pro-Comp shocks!!!!
Posted: Fri Mar 30, 2007 10:01 am
by Leafster
Well, I installed the new Pro-Comp shocks on the front last night after also replacing the sway bar bushings with Energy urethane ones and giving it a full chassis lube. All I can say is WOW! It's a completely different van. Super stable, not bouncy anymore, it's just awesome.
On another note, we also had the rear springs re-arched to bring them back to life and have ordered Pro-Comp shocks for the rear. The whole van is so much more stable than last week when we picked it up.
I'll post some pictures in the next few days once we have finished painting the new wheels and installing the tires.
Pro-Comp part numbers
Front 313515
Rear 319520
$55 each North Shore Off-Road or your local suspension shop.
suspension
Posted: Fri Mar 30, 2007 11:23 am
by sid
You are right, what you did makes SO much difference, and its not that expensive and relativley uncomplicated. that, plus good rubber, and an alignment should be one of the madatory upgrades. the change is dramatic.
Re: Pro-Comp shocks!!!!
Posted: Mon Sep 03, 2007 6:16 pm
by mitsu
Just wondering where you found the sway bar bushings - the Energy urethane ones, and do you have a part number and make for them?
Re: Bump Pro-Comp shocks!!!!
Posted: Fri Sep 05, 2008 7:37 pm
by snelson
Bump
Any word on those Energy bushings - where to get them?
Got my shocks from Mardy, installing them tomorrow morning
Posted: Fri Sep 05, 2008 10:07 pm
by Profister
I replaced the original shocks with ProComp 9000 ones and did not feel any difference. I am not sure what people are talking about regarding the huge improvements in stability etc.
Posted: Sat Sep 06, 2008 12:19 am
I got Rancho 9000s from NSOR, they did a really good job, but tell me: Was it at NSOR that you got the leaf springs re-arched? Or elsewhere? This is on my to-do list.
Posted: Sat Sep 06, 2008 5:36 pm
by quadzilla
Sway Bar Bushings: Energy suspension 98101R: polyurethane
Got mine at NAPA auto parts. Cheap. Big difference.
Posted: Sat Sep 06, 2008 8:18 pm
by delicat
Profister,
Had the same opinion with ProComp then I re-indexed my torsion bars and the ride is how I like it, firm for city driving but absorbs big time for off-roading. I should have tried re-indexing first but didn't realize it would make such a difference. I had the torsion bars cranked up but guess that wasn't enough. I'm good with them now.
David
Posted: Sun Sep 07, 2008 12:48 pm
by jrman
I think the ride improvement is going to be directly related to the condition of the shocks each person's vehicle arrived with. Mine were clearly in terrible need of replacement - the van bounced and dove like crazy. The Procomps were a massive improvement and very gratifying upgrade. Cannot comment about any other alternatives of course, but I believe that the shocks on my man when it landed in Canada were very likely the ones it left the MMC factory with!!!!
Posted: Mon Sep 08, 2008 5:31 pm
by rdub
Gas shocks are a bit softer than hydrolic shocks,hydrolic last a little longer if that is what you put in.
Posted: Mon Sep 08, 2008 7:03 pm
Procomp's that begin with 3xxxxxx are the 3000 series (hydraulic)
Procomp's that begin with 9xxxxxx are the 9000 series (gas charged)
After trying out both extensively (city/hwy/offroad) I prefer the 3000 series for the Delica.
If I was to only drive on concrete in the city, then I would choose the 9000's.
Posted: Tue Jan 25, 2011 5:23 pm
by CV-25
There is no problem putting Pro Comp 3000's on the front and Pro Comp 9000's on the back is there?
Posted: Tue Jan 25, 2011 5:46 pm
by fexlboi
Not really, but ideally you want the stiffer shocks on the front of a Delica.
Posted: Tue Jan 25, 2011 8:42 pm
If you put 3000's on the front, you will get a lot of body roll side to side when corning and front pitching when braking due to the soft oil shocks.
9000 series or a harder/gas shock is recommended for the front
Posted: Wed Jan 26, 2011 1:34 am
by CV-25
rdub wrote:Gas shocks are a bit softer than hydrolic shocks,hydrolic last a little longer if that is what you put in.
rdub wrote:Procomp's that begin with 9xxxxxx are the 9000 series (gas charged)
Don't you want the 3000's (stiffer?) on the front because the gas 9000's are softer?
slightly confused...still have not purchased my front shocks but don't want to mess it up
CV-25
