Delica Truck Questions
Posted: Sun Jan 18, 2009 8:42 pm
by psilosin
Looking at picking up a single cab 4x4 Delica truck. Apart from the engine being sans turbo is the drivetrain and suspension essentially the same as the Delica Van?
I would like to give it a little lift and wanted to know if existing Delica Van lift solutions would work. Also the truck suspension is very stiff, as expected with 850kg payload capacity, but a little too stiff for comfortable unloaded daily driving and too stiff for good flex and traction for unloaded off road adventures. Wondering if some of the suspension setups from the Vans might be a straight swap over for a more relaxed ride?
Re: Delica Truck Questions
Posted: Sun Jan 18, 2009 9:44 pm
Torsion up front you can loosen the tension or change the shocks
Leaf pack on the rear. you can pull a leaf out and have them re-arched . that will add more sway/bounce and pull the sway bar off the rear as well. more flex
