Wheels and tires
Posted: Sun Apr 08, 2007 5:51 pm
by Adrock
Got 5 15x6 wheels for a deli. I believe they have been painted white... or an almsot white color, 215/80/15 tires I believe. One is on its way out but the others may have some life, I'd recommend new tires for them at some point in the near future though.
Nice looking wheels, can include the hub covers if you so please.
$200 for all 5 obo.
Tires for sale
Posted: Thu Apr 12, 2007 8:22 pm
by sean
Hi Adrock,
Do you think that the one that is on the way out would pass a safety inspection
Posted: Thu Apr 12, 2007 10:14 pm
by Adrock
i dont know, don't they just look for DOT? I have 5 anyways, 1 has never been used but is a bit cracked, never actually looked if that one was dot though...
Posted: Thu Apr 12, 2007 10:46 pm
by sean
You could be right. They may just look for DOT. I will look into it.
Thanks :D
Posted: Fri Apr 13, 2007 9:32 am
by josh
You also need a percentage of tread left don't you? I am not sure on the amount... maybe 60% (thats a stab in the dark really)
Josh
Posted: Fri Apr 13, 2007 12:38 pm
by Adrock
honestly, i'm selling the rims. The one tire is pretty gone, the rest are ok, but i'm not a tire expert. I'm sure someone else could tell me that they are horrible and should never see pavement again, or that they have 70% left. I have no idea.
Tire regulations
Posted: Fri Apr 13, 2007 3:12 pm
by ccautos
Tires DO NOT have to have DOT on the side walls but to pass inspection into BC they do need to have Max load rating and Max pressure rating . To meet DOT regulations the inspector has to be aware of what the tire is capable of to pass .
Posted: Fri Jun 08, 2007 10:19 am
by Pajerist
josh wrote:You also need a percentage of tread left don't you? I am not sure on the amount... maybe 60%
To pass OOP in BC you should have at least 50%.
Re: Tire regulations
Posted: Fri Jun 08, 2007 10:21 am
by Pajerist
ccautos wrote:Tires DO NOT have to have DOT on the side walls but to pass inspection into BC they do need to have Max load rating and Max pressure rating . To meet DOT regulations the inspector has to be aware of what the tire is capable of to pass .
In theory you are right, BUT in life THEY require DOT plus Max load pressure rating.
Telling you as recently pass OOP, was forced to install new set of tires
Re: Wheels and tires
Posted: Wed Sep 05, 2007 5:24 pm
by patty
Does any one know the max width of a tire you can put on a stock suspention delica chamonix.I want to get some that some what stick out abit from the sides of the vehicle for swifter corners and a sweeter look.
One of my tires ripped apart the other day commin back from Princeton,all the layered seperated and when it did so the flappy rubber ripped apart my wheel wel.So that was pretty freeky,i deffinalty want to get a beafier tire just to make me think its not gonna happen again.I know that if I lift the vehicle I could get bigger more aggressive tires,but right now i can barley fit in underground parking lots and thats pretty much a MUST for skiing from creekside.
Posted: Thu Sep 06, 2007 11:50 am
by Adrock
31s will fit with torsion bars maxxed and some cutting and bashing, standard width for those is 10.5 inches, and they will fit on a 7 inch rim (biggest width problem is sliding door clearance) You can use stock rims and get a 30 inch tire, usually 9.5 inches wide, basically, you can go as wide as you want as long as you dont impede the sliding door, unfortunately there is no set number for what wheel with what backspacing and what width tire will fit and what won't. I know my 15x7 wheels with 4.25 inch backspacing, and 31x15x10.5 mud terrains fit... barely. I think any 9.5 inch wide tires will be just fine.
Posted: Thu Sep 06, 2007 8:34 pm
by patty
Do you own your own grinder?Im also not sure on where i should go to get a good set of tires,does it really matter?I was going to go just to canadian tire because its close and easey,would this be a mistake?
Posted: Thu Sep 06, 2007 8:46 pm
by EricN
http://www.tiretrends.ca/ or Costco. You won't find too many places that beat Costco $$$. Try and avoid cheaper brand tires if you can (ie: motomaster), they generally dont wear evenly and tend to more prone to separate.
Posted: Thu Sep 06, 2007 9:18 pm
by Adrock
get a good brand, where you go for that brand depends on how much you want to pay. Best price I found was discount tire co in surrey. They were great. Costco was very close in price but didnt have them in stock the day I wanted them... I suck at waiting for things. 30x9.5 BFG all terrains would be nice tires. haha.
