I was wondering what the shops in bc have charges to change the following stuff:
Timing belts /belts/ idler pulley etc.
Water pump, seals
on a '90 Exceed
Im not so much interested in the hourly rate but how many hours it should take.
James
Shop hours to change the...
- Firesong
- fishslapper
- Vehicle: 1994 lwb l400
Re: Shop hours to change the...
most just seem to charge a flat rate
anywhere from $850-$1000 for the whole thing including parts. timing belts water pump and oil seals.
happy driving.
cheers isaac
happy driving.
cheers isaac
The Mighty Boosh !!
The cost of the job depends considerable on your definition of what a "timing belt change" means.
The parts list is typically a lot longer than just the timing components and a water pump.
Add:
accessory belts
coolant flush
coolant
oil & filter
rad hoses
thermostat
radiator cap
valve cover gasket
~ and so on ~
The prices for this work varies greatly.
~John
Add:
accessory belts
coolant flush
coolant
oil & filter
rad hoses
thermostat
radiator cap
valve cover gasket
~ and so on ~
~John
E4 Auto Repair Ltd.
& Radd Cruisers 4WD
Duncan, BC
250 746 8977
& Radd Cruisers 4WD
Duncan, BC
250 746 8977
- Firesong
I was just asking for the hours for what I had listed.
Nothing complicated. You must be from a shop ;)
Anyway, got my Delica back today. Happy Happy Joy Joy.
James
James
