Runs great.... but....
Posted: Fri Aug 07, 2009 12:28 pm
by Spearo
Before I start digging into things: a few times this week, turning off the ignition did not result in the Smellica stopping. There is a stupid turbo timer that has worked 1 whole time since I bought it, turns itself on/off at random, but has otherwise been useless. These times the little POS was not lit up but the fuel kept pumping.
Any suggestions amigos/amigas? Besides the 5lb sledgehammer precision tool option of course :shock:
Thanks and have a great weekend- I'm off to Jasper.
Re: Runs great.... but....
Posted: Fri Aug 07, 2009 12:31 pm
by Golf Cart
Sounds like a sticking fuel solenoid on the IP
Posted: Fri Aug 07, 2009 12:33 pm
by Green1
2 possibilities:
1) that turbo timer is being a pain
2) your fuel shutoff solenoid is being a pain
troubleshooting:
1) disconnect the turbo timer
2) see if that solves the issue
3a) if so, get rid of the turbo timer
3b) if not, look in to replacing the fuel shutoff solenoid.
Posted: Fri Aug 07, 2009 1:10 pm
by loki
I have, occasionally, had my van kept running after I turn the key off but all I have to do if turn off the lights and it shuts off, it's not very often though so it is weird. So you might want to look into that as well.
Posted: Fri Aug 07, 2009 1:13 pm
by Spearo
Wow, that was quick! You guys must be as busy as me today at work lol.
Thanks for the input- gives me somewhere to look.
And that turbotimer will be binned shortly. I just want to make sure I unhook all the right things.
Posted: Sat Aug 29, 2009 6:05 pm
by Erebus
loki wrote:I have, occasionally, had my van kept running after I turn the key off but all I have to do if turn off the lights and it shuts off, it's not very often though so it is weird. So you might want to look into that as well.
When that is the case, it is usually the daytime running lights (DRL) that are the cause. They are backfeeding the ignition.
Fix the DRLs and you problem will go away. (If that is the issue, of course!)
