Not all marker lights working.
Posted: Sat Nov 07, 2009 2:23 am
by TardisDeli
Anyone had this problem ? Where the rear tail marker lights are working but not the front marker lights. I suspect there is a splitter/'brain box' somewhere but where its located i don't know. Also where is the door lock module on a 91 Deli with standard transmission it's not in the same location as our 91 automatic Deli .Which is above the steering wheel on the fire wall,which is a pain to get at. Cheers Jay Tardis.
Re: Not all marker lights working.
Posted: Sat Nov 07, 2009 6:38 pm
by almac
wow. too many replies...
jay. i talked to a guy today at an autoelectric place, and he thinks it might be the switch on the steering column.
what i cant figure out, is that if it is the switch, then why are only the front lights not working?
i wonder what THAT will cost me...glad i held off on the other mods...
BTW: thanks a lot for your help over the last few days. i really appreciated it.
the electrical issues were a pain, but the deliMEET was great!
you and christine ARE GOLDEN.
i hope one day to return the favor.
Posted: Sat Nov 07, 2009 6:53 pm
by Green1
when an electrical issue stumps Jay... the rest of us become too scared to even guess!
Posted: Wed Nov 11, 2009 11:07 pm
by almac
hey tardisdeli jay.
just an update.
while drivin my deli tonight, i noticed that the white side marker lights under the signal lights DO WORK.
strange thing is that they only work when im signaling... they do not flash, they just light up.
is this normal? i thought they were supposed to be on when the park lights were on??
the one on the drivers' side is dim... probably a bad connection.
Posted: Thu Nov 12, 2009 8:19 am
by Green1
almac wrote:hey tardisdeli jay.
just an update.
That is perfectly normal, those are "cornering" lights, designed to let you see around dark corners when you put your signals on, not all that usefull in well lit cities, but on dark back roads they're awesome!
