tires
Posted: Fri Nov 20, 2009 7:24 am
by Firesong
See the below post.
Re: tires
Posted: Fri Nov 20, 2009 7:32 am
by Firesong
I am looking at these to buy used
Rims and tires from a Nissan Pathfinder 6 bolt pattern
265/70R15 MIC X-Ice Latitude BW 112Q
A tire size calculator shows that they would be:
9.25" (stock width) to 10.24"
28.8" diameter to 29.6"
Will they fit an unlifted L300 deli?
Bolt pattern and no rubbing?
It would be nice if I could just bolt them on and ware the rubbing?
J
Re: tires
Posted: Fri Nov 20, 2009 7:56 am
by Erebus
Firesong wrote:Hi
I have the stock aluminum rims for my l300
I think I have 235...'s on it.
Can these tires fit the rims?
245/75/R16
Not likely. The stock rims are 15" so 16" tires would be just a tad loose.
Re: tires
Posted: Fri Nov 20, 2009 11:25 am
I sent you a pm.
If they are on stock nissan rims they may fit. You'll have to remove the front mud flaps and may need to lift the front end up via torsion bar if it's sagging
