installing 12 volt electronics on a 24 volt vehicle
Posted: Sun Dec 06, 2009 12:42 am
by Frisch
Does anybody have any experience with voltage converters?
I'd like to install a WVO kit on my 24 volt truck (canter) and I'm thinking of using a converter to set up something of a 12 volt "station" of to run all the 12 volt electronics.
What's the best converter to use or Is there a better way?
Re: installing 12 volt electronics on a 24 volt vehicle
Posted: Sun Dec 06, 2009 8:42 am
by delicat
If you don't find the info here you should go check:
http://forum.ih8mud.com/diesel-tech-24-volts-systems/
They have a diesel section where 24V converter has been well covered.
Good luck!
David
Posted: Sun Dec 06, 2009 9:32 am
by after oil
Frisch wrote:Does anybody have any experience with voltage converters?
i have a wvo kit for 24 volt. the valves, relays and the glow plug are all 24.
this is my 12v kit installed in my delica
http://www.delica.ca/forum/space-antelo ... -3508.html
Posted: Tue Dec 08, 2009 3:33 pm
by AndrewH
I can put a kit together with 24v valves and relays if need be, might just be easier to convert a source to 12v as most of the easily available heaters and what not are 12v.
Andrew
