I'll keep you guys posted and I'm sure we can make the Ikea meet.
It's actually (the chair swap) quite simple.
Remove 4 bolts on original front passenger chair.
Remove chair.
Peel back carpet and remove thick foam insulation.
Take L400 middle-row captain's chair from donor vehicle and put it in reversed (front at back and back at front).
This way, 3 of the 4 original passenger seat bolt holes in the floor line up.
I will have to do 3 modifications to the donor captain's chair to have it a) fit properly and b) be just as safe as the original.
1. cut 8" inches of track at the back so it doesn't run too far back where the sliding door entry/exit is.
2. weld two flatbar pieces of steel (green in the pic below) to line up with the existing hole.
3. drill a single hole through floor and nut/bolt through the new bracket.
Probably 1hr of fabricating/playing around at most.
I don't mind explaining it/showing it/helping other do it in the future although I will not accept liability for the modification as it does change the passenger seat.
With that said, once bolted in, it's just like the original (seatbelt, placement, etc...)
*pics below borrowed from other thread.
