Injector cleaning
Posted: Tue Mar 02, 2010 11:46 am
by strada-caster
Hi, just looking for the best place on the island to get my injectors checked/cleaned and if needed replaced. Thanks in advance.
Re: Injector cleaning
Posted: Tue Mar 02, 2010 1:06 pm
by Luna-Sea
Action Fuel Injection
2219A McGarrigle Road,
Nanaimo, BC
V9S 4M4
(250) 758-3221
There should‎ should be some diesel place down
in your neck of the woods too.
If you pull your injectors yourself,you will save considerably.
Right ON! 8-)
Posted: Tue Mar 02, 2010 2:12 pm
by loki
Luna-Sea wrote:Action Fuel Injection
Nanaimo, BC
V9S 4M4
(250) 758-3221
Right ON! 8-)
pretty sure there is a new place south island as good as action, my Dad's company (Vector Yachts) always sent to action but I thought I remember him mentioning a place closer as good and cheaper, you could call Vector and ask where they send their injectors for rebuild/cleaning.
Posted: Thu Mar 04, 2010 11:11 am
by strada-caster
does ccautos do this kind of work? i'll have to give them a call.
Posted: Thu Mar 04, 2010 1:39 pm
by loki
strada-caster wrote:does ccautos do this kind of work? i'll have to give them a call.
they may clean them but most places send out to the specialists for rebuilds.
Posted: Fri Mar 05, 2010 9:05 am
by strada-caster
gave ccautos a call, they do not do this kind of work.
action fuel injection in nanaimo &
wilson&proctor in victoria both do this work. they are comparable in price by $5 /injector.
thanks for the input guys.
Posted: Wed Mar 10, 2010 5:42 pm
by ccautos
The only service we offer is to remove and replace the injectors. I prefer to send out the injectors to the specialists (Action Injection) who rebuild the injectors and test spray patterns. The injectors only cost $85 each fully rebuilt with a 12mth warranty, why waste the money just cleaning them ?? Injectors rarely have many problems in these vans, normally the symptoms are due to another cause but occasionally we have found injectors that have been overheated and the tips are quite burnt. Cleaning injectors does not deal with burnt tips or recalibrating. Also be very careful to insure the shop that removes and replaces the injectors uses new heat shields every time as this seal is a one time use seal (crush style) and should be replaced every time the injector is removed from the engine. We are seeing many vans coming into our shop that have not had the tip heat shield replaced and is is causing overheating of the injectors which in turn leads to replacing with refurbished injectors.
Do the job once and do it right !!! Rebuilt injectors and all new seals - job done.
Posted: Thu Mar 11, 2010 11:28 am
by strada-caster
ccautos wrote:The only service we offer is to remove and replace the injectors. I prefer to send out the injectors to the specialists (Action Injection) who rebuild the injectors and test spray patterns. The injectors only cost $85 each fully rebuilt with a 12mth warranty, why waste the money just cleaning them ?? Injectors rarely have many problems in these vans, normally the symptoms are due to another cause but occasionally we have found injectors that have been overheated and the tips are quite burnt. Cleaning injectors does not deal with burnt tips or recalibrating. Also be very careful to insure the shop that removes and replaces the injectors uses new heat shields every time as this seal is a one time use seal (crush style) and should be replaced every time the injector is removed from the engine. We are seeing many vans coming into our shop that have not had the tip heat shield replaced and is is causing overheating of the injectors which in turn leads to replacing with refurbished injectors.
Thanks for the clarification, I obviously informed the forum of your services incorrectly. Thanks for the info on what you so aswell. very informative.
85bucks/injector sure beats another quote i recieved at 170bucks/injector (wont mention who gave me that one).
Posted: Sat Mar 13, 2010 4:52 pm
by Rising Sun Auto Import
We are selling a brand new set (of 4) Injector for $400, made by Hyundai. Individual price is $120 ea.
