NEEDED: 1990 4G64 ECU CODES
Posted: Wed Mar 10, 2010 9:45 am
by Yokohama
I need the ECU codes/testing procedure (is there a plug for ECU testing?) for a 1990 USA spec L300 with 4G64. I presume that the 90 ECUs would all use the same codes, maybe.
Thank you.
Re: NEEDED: 1990 4G64 ECU CODES
Posted: Wed Mar 10, 2010 11:38 am
Have you checked out "FAQs & Downloads" in "Delica Canada Technical"? It's in the forum index. You will find the 4G64 engine manual there.
Posted: Wed Mar 10, 2010 2:35 pm
by Yokohama
Thank you, but the manuals dealing with the EFI system on this site appear to only cover the V6 and diesel models. I have the gasoline 4-cylinder, unless the codes for whatever year of V6 ECU is in the manuals is the same for the 1990 4-cylinder 4G64 ECU.
Posted: Wed Mar 10, 2010 4:30 pm
by Green1
Yokohama wrote:I need the ECU codes/testing procedure (is there a plug for ECU testing?) for a 1990 USA spec L300 with 4G64. I presume that the 90 ECUs would all use the same codes, maybe.
Thank you.
I'm not familliar with the gasoline version of the vehicle, but I can tell you that the diesels certainly didn't have an ECU, and I would be extremely surprised if the gas version had an ECU test plug...
Posted: Sun Mar 14, 2010 10:44 am
by Yokohama
I found the codes. It has a diagnostic port above the fuses; it gave the code for bad ECU.
I found that the ECU suffers from similar capacitor leakage to the DSM's ECU. I either have to repair my ECU or find another one.
Posted: Sun Mar 14, 2010 7:30 pm
Where did you find the codes? I can load them into the L300 Delica Downloads forum.
