FS: Camperized Delica l300 aka DINO - SOLD
Posted: Sat Mar 27, 2010 8:40 pm
DINO has been very good to us and NEVER let us down. He got treated very well and a lot of preventive work has been done to keep him happy for a long time. We hate to see him go, but we can not justify two l300s in our driveway. If you are looking for a clean, camperized van with a reliable record no surprises, check it out.
Here are the details:
1993 Mitsubishi Delica Exceed (P35W) High roof with Crystal lights, 190,xxx km, Automatic
Exterior:
• ProComp 9000 shocks with polyurethane bushings
• DevilsOwn Methanol injection including 1 Gallon reservoir
• 5 x custom powder coated black tear drop alloy rims
• Two 8" PIAA off-road lights (ultra white PIAA bulbs, high- and low beam)
• Custom removable bike rack on the front bull bar
• Almost new 235/75 Hercules Terra Trac tires
• 4-wheel laser alignment and torsion bars re-indexed
• After-market clear window visor
• Dark Tinted Windows
• E-code DEPO headlights
• Front quarter panels sealed (no wet floors)
• All polyurethane bushings
• No rust, no black or white smoke
• All window seals are greased and leak free.
Interior:
• Custom mattress (74" x 54") with high-density 4" foam and Sunbrella water-repellent fabric
• Two slide-out tables (very convenient for camping)
• Custom folding bed with tons of storage room (can be removed within a few minutes to get a big cargo area)
• Rear bench has shoulder seatbelt
• Professionally upholstered front seats with reinforced springs
• Solenoid for second battery and three 12v power outlets in the back
• VDO Pyrometer gauge fitted in dashboard pod
• After market 14" wood steering wheel
• Brand new curtains
• Non-smoking vehicle
• 6 1/2" Alpine speakers in front doors
• Custom plywood and heavy-duty rubber flooring ( http://www.delica.ca/forum/dino-s-new-f ... -4282.html )
Maintenance:
- Injection pump rebuild
- All belts, tensioners, water pump and thermostat replaced at 167k km
- New brake discs/pads and drums machined at 167k km
- Front hubs are repacked and greased
- New transmission mounts
- CVI "Delica Tune"
- Front and rear differentials serviced (synthetic gear oil)
- Stabilizer sway bar polyurethane bushings
- New engine oil and transmission fluid
- Ball joints, tie rods and drive shaft greased
- Turbo has no leak!
- No oil and fluid leaks!
• Always fully serviced at CVI in Richmond using Japanese parts and synthetic engine oil
• Next major service required at 257k km (timing belt, water pump...)
• Big inspection by CVI last week without any issues, feel free to give them a call.
• Well maintained and very reliable, purchased from Terra2 with 157k km two years ago
• Full BC certification
Exterior:
Interior:
Maintenance:
- CVI "Delica Tune"
