wiring diagrams
Posted: Tue May 04, 2010 10:12 am
by Breanne
Hi my delica L300 is having an issue starting in park.... if i put it in neutral it has no issues ... any clue?
also if anyone has a wiring diagram they could post that could help me out a lot
cheers bre
Re: wiring diagrams
Posted: Tue May 04, 2010 11:34 am
Go to the forum index (click on "forum" up in the top left of your screen), then go to: Delica Canada Technical/FAQ and Downloads/L300 Delica Downloads/L300 Electrical Wiring Diagrams & Manual.
Then click on Engine Electrical Manual.
The forum index can be quite the useful tool... smiles.
Re: wiring diagrams
Posted: Tue May 04, 2010 12:01 pm
by loki
there are many posts in the L300 tech section of people having this issue, usually turns out to be the safety switch in the shifter, you can get the part from Amazing Auto Imports, CCAutos, or Rocky Mountain imports.
Re: wiring diagrams
Posted: Tue May 04, 2010 4:45 pm
by TardisDeli
Agree with Loki, sounds like the neutral safety switch died. Christine.
Re: wiring diagrams
Posted: Thu May 06, 2010 10:28 pm
by Breanne
i found the issue it was to do with the gears... when i took off the cover from the gears there was an adjustable rod that when extended engages the parking gear... who knew???i guess it had vibrated loose
