Headlamp switch troubles?
Posted: Wed May 19, 2010 7:26 am
I've read a bunch of posts on this topic and have come to the (almost) conclusion that my headlamp switch is toast. I'm hoping someone can confirm that I'm on the right track before I pay big bucks for another one.
I lost my headlights, taillights, and dash lights simultaneously. The fuse is good.
High beams still work, running lights still work. But I blew the horn and high beam fuses shortly before.
I'm thinking headlamp switch, but also wondering about the relay unit. Would a defective relay cause the same issue?
Looks like I'll have to do the DRL modification to dump extra load, but I'm also wondering if my trailer wiring could be causing extra load or ground problems.
Anyone have some wisdom to share?
Thanks,
Shane.
Thanks,
Shane.
