Nice shot Rich
gramadin wrote:Hi, I always wandered, do you need some mods on your vehicle to drive on sand?
I have a stock LWB Pajero, and I wanna try it, but I am always afraid of getting stuck.
Any input will be appreciated.
http://www.offroaders.com/info/tech-cor ... nd_dri.htm
Sand Driving Techniques
When traveling on sand, you should endeavor to follow in the tire tracks of the vehicle in front as they have already compressed the sand to form a firmer surface than un-traversed ground. Never drive on vegetation as this will destroy it and lead to erosion and environmental damage.
You should avoid rapid changes in speed when accelerating or braking. Braking on sand will cause a mound to build up in front of all wheels and possibly prevent your vehicle from taking off. Rapid acceleration simply digs the wheels in and can actually lead to slower take-off speeds.
Take-off should be performed as smoothly as possible with gear changes done at fairly high revs. Sand driving requires plenty of engine power to get your vehicle "planing" on the sand. It is advisable to use low range as this multiplies the amount of engine torque available and will provide that extra gear if you encounter a particularly soft patch of sand. Check that your tires are pointing straight ahead when taking off to reduce the takeoff effort required.
When stopping on sand, depress the clutch and allow the vehicle to coast to a stop. This will minimize any sand build-up in front of the wheels. If the terrain permits, coast to a stop, rather than braking, with the vehicle pointing downhill as this will aid take-off. Avoid the soft sand at the base of most dunes and gullies when stopping.
When turning, make the turn as wide as possible to reduce the chance of bogging. Your front wheels act more like a rudder in sand and turning too sharp has a similar effect to applying the brakes.
Steep sand dunes can be traversed only straight up or down. If you drive even on a slight angle, the weight transfer is to the downhill side wheels. If the vehicle starts to slip, the downhill wheels tend to dig in and make the angle of the dune even worse, leading to a potential rollover.
If you are traveling straight down a steep dune and the back end starts to slip sideways, it is best to accelerate slightly to try and straighten the vehicle. Never use the brake, as this will cause weight transfer to the front wheels and can increase the back end movement.
If traveling up a dune and you do not get to the top, reverse down the dune in gear, NEVER coast down the dune and NEVER attempt a U turn.
When you return home after a beach trip, it is important to hose down your vehicle to remove all traces of sand and salt. Pay special attention to areas like the mudguards where sand is sprayed around and tends to get trapped. Thoroughly hose underneath your vehicle as well, as there are many nooks and crannies where sand con also get trapped.
