Air Lift kit for L400
Posted: Wed Mar 27, 2013 8:14 am
by prairiefire
My van has a saggy backend and I'm looking to solve that. I put one of Jesse's lift kits a couple years ago on it but left the rear springs stock. I'm looking at either putting in an Air lift kit in or new springs and a kit. If I stay with stock springs I'll leave the lift spacers in. My main question is what kit number should I order. I've found a couple posts on here that lay out the kits they used.
http://www.delica.ca/forum/which-spring ... 11949.html
http://www.delica.ca/forum/spring-rate-l400-10171.html
So those posts leave me with the following options.
http://www.summitracing.com/parts/AIR-60747/
http://www.summitracing.com/parts/air-61792
http://www.summitracing.com/parts/air-60792
Does anyone have an idea which would be the correct one?
thanks,
K
Re: Air Lift kit for L400
Posted: Wed Mar 27, 2013 9:13 am
by Profister
PM sent.
Posted: Thu Mar 28, 2013 6:47 pm
by Artacoma
Posted: Sat Apr 06, 2013 12:26 pm
by prairiefire
So on the advice or Profister I checked out
http://www.lowriders.ca/ for my Air Lift 1000 kit. This place is a little out of the way but well worth the drive. The sales guy (Gary?) went out and measured up the springs and got on the phone to Air lift to cross reference the replacement bags and the full kits. We found out the proper fit for my L400 this way. I have one of Jesse's lift kits on and the coil spring spacers compress the back quite a bit. As per Profister and Aciled if you DON'T have a lift the proper kit is #61792. If you're like me with the rear spacers the proper kit is #60792. I'll post an update when it's installed. Hope this helps any interested parties and do support Lowriders Unlimited...Top Service.
Posted: Sat Apr 06, 2013 6:59 pm
by del400
I have the kit and I might be selling it if anyone is interested.
Alex
Posted: Fri May 17, 2013 5:52 pm
by macro
prairiefire wrote:So on the advice or Profister I checked out
I just installed HD springs AND air bags, its awesome. I would recommend doing both.
Posted: Fri May 17, 2013 11:56 pm
by del400
Funny Enough. I just got my van back today with the lift in. It's INSANE!!! worth every penny. Picture to come.
And the air bags are in as well. Car is super stiff.
Awesome
Posted: Sat May 18, 2013 12:44 am
by Glenn Delwood
Just put airbags in today. No lift. What psi did you pump to in order to get it stiff?
Glenn
Posted: Sat May 18, 2013 11:23 am
by macro
I think I'm running at 20 right now. I would start at the max pressure and then drop down by 5 until you find what you want. I think it depends on the condition of your springs too, the softer the spring, the more pressure you'll want. 10 was a nice ride but 20 gives me the lift I want for the back, and I usually have a bit of weight back there anyways.
Posted: Wed May 29, 2013 10:08 pm
by Glenn Delwood
Macro,
Does it squeak now? Mine kinda does. Is that normal? Is there some lubricant for that plastic/silicone whatever it is and the springs (to stop or minimize the squeaking)?
Re:
Posted: Thu May 30, 2013 3:43 am
by macro
Glenn Delwood wrote:Macro,
Mine don't squeak at all. When you put them in did you have them inflated to max pressure before you settled the vehicle weight back on them? Maybe try pumping them back up to the max pressure (35psi I think?) and then go back down 5 at a time, drive around, let them settle in.
