Delica Parts
mdrive
Delica Parts
Post by mdrive »
Brand New Parts:
WATERPUMP $150. GMB JAPAN
FRONT BRAKE PADS: $35. GENERIC
REAR SHOE: $70. AFTERMARKET JAPANESE
REAR SHOE RELINED: $55. LOCAL
OIL FILTER: $20. TAIWAN
FUEL FILTER: $25. TAIWAN
AIR FILTER $25. TAIWAN
FUEL PUMP REBUILD KIT: $65. JAPAN
TENSIONERS: $40. GMB
DISC ROTOR: $65. KOREA
TIMING BELT: $42 GERMANY
TENSIONER BELT: $40 SINGAPORE
TIE ROD END OUTER: $57. TAIWAN
BALL JOINT: $55. TAIWAN
HEADLIGHT: $350.
FRONT QUARTER PANEL SHEET METAL: $30. TAIWAN
OVERHAUL HEAD GASKET FULL SET: $85. TAIWAN
BRAKE MASTER CYL KIT; $40. TAIWAN
TAIL LAMP: $40 TAIWAN
Prices are suject to change without Notice. Promotional Offer, Limited Time only.
39Ronin
Vehicle: Mercedes Benz Gelandewagen 300GD
Post by 39Ronin »
Is this new stuff or used?
surferboy
Post by surferboy »
yeah, and where are those parts from, any warranty? what if the part fails after installation, who will be responsible if it caused major dammage to the engine? Thanks for any further infos as to where these parts are manufactured and by who...
mdrive
Post by mdrive »
all parts are New
most parts are from Japan. Filters are from Taiwan. Bearings are from Germany.
This is promotional price and limited time offer only.
Parts are under warrenty however, detailed will posted as soon as you identify the parts you need.
