Engine Oil
4D56 Diesel: 15W40 Diesel oil meeting JASO DH-1 (I use API CI4-plus) 6.7l (5.9 without filter)
Petrol: 10W40 or 10W50 SG 3.9l (3.4l without filter)
Manual Transmission 75W-85W GL4 2.0 litres (Avoid GL5 oil unless it specifically states it is "yellow metal safe")
Transfer Case 75W-85W GL4 or GL5 2.2 litres
Automatic Transmission Dexron2 (or later) 6.8 litres (from dry)
Differential:
Conventional Hypoid 80W or 90W GL4 or GL5 (Front 1.1 litres, rear 1.8 litres)
Limited Slip Castrol LS90 or LSX90 GL5 or GL6 (rear 1.8 litres)
Power steering Dexron2 0.9 litres
Cooling system Water plus Mitsubishi inhibitor (or any quality antifreeze with corrosion inhibitors) approx 8.7 litres
Brake Fluid DOT4
Wheel bearings, steering and front suspension joints, propeller shaft: Lithium based EP no.2 grease
Source: '87-'94 Technical Data PDF. (http://www.delica.ca/forum/viewtopic.php?f=17&t=292)
L300 fluids
Flyers and technical information relating to the L300 Delica
L300 fluids
Return to “L300 Shop Manual Downloads”
Jump to
- Delica Canada General
- ↳ Member Introductions
- ↳ General Discussion
- ↳ Events
- ↳ Events - Other BC
- ↳ Events - Alberta
- ↳ Events - Saskabush
- ↳ Events - Manitoba
- ↳ Events - Ontario
- ↳ Events - Atlantic Canada
- ↳ Events - North Of Sixty.
- Delica Canada Technical
- ↳ L300 Engine
- ↳ L300 Body
- ↳ L300 Overview
- ↳ A/C & Heating Systems
- ↳ Cooling & Oil Systems
- ↳ Intake & Exhaust
- ↳ Drive Train
- ↳ Front & Rear Axles
- ↳ Suspension & Brakes
- ↳ Body Electric
- ↳ Body General
- ↳ A/C & Heating
- ↳ Cooling & Oil
- ↳ Drive Train
- ↳ Body Electric
- ↳ Body General
- ↳ L300 Technical
- ↳ L400 Technical
- ↳ Delica Modifications
- ↳ WVO and Biodiesel
- ↳ Pajero
- ↳ Strada
- ↳ Mitsubishi Vanwagon
- ↳ Mitsubishi Kei
- ↳ Delica Wiki
- ↳ Radio Communications
- Sightings, Stories & Photos
- ↳ Was it You?
- ↳ Member Trips
- ↳ Member Rides
- ↳ Delica Photos
- ↳ On the Web
- Purchasing & Importing
- ↳ Tool Swaps, Share, Trade
- Feedback
- ↳ Archives
- ↳ Vehicle Sales
- ↳ Sales by Other Importers
- ↳ Sales by Private Members
