Restoration of my delica
tiitus
Vehicle: Delica L300
Post by tiitus »
I but here some story, when I try to fix my car.
First, there was a some engine warm up problem, so I change
thermostat, piece of cake.
Also alternator belt was little over used. :-D
My back is now painful, so tomorrow I try on a new belt.
Re: Restoration of my delica
Wow. That's quite the alternator belt... Have you checked the timing belt lately? If your alternator belt breaks then you are without electrical charge. If your timing belt breaks then you are without engine.
tiitus
Post by tiitus »
Yes that I have to do soon as possible.
Some years a go I even made a note for 4D56 engine.
It`s a finnish but pics tells a lot. :-)
http://www.mitsubishi4wd.com/oppaat/jakopaa.htm
MrDuncon
Vehicle: '95 L300
Post by MrDuncon »
I can ensure you, that will be a calming feeling when you will get over these things.
When I changed the timing belt i also replaced the water pump, and all of the belts.
They come together ;)
Good luck!
Sorry for my English
Photo blog: zoltansz.tumblr.com
Blog: jdmjinsei.com
tiitus
Post by tiitus »
MrDuncon wrote: When I changed the timing belt i also replaced the water pump, and all of the belts.
Good luck!
Don`t forget oilseals, or all hard work can be a waste of time. :-)
Absolutely. Before I first purchased my Starwagon I paid $200 and got her checked out. As she had been sitting for a time in Yokohama, her oil seals had dried out some and even though the timing belt had recently been changed it was all for naught because there was oil all over it. Hot oil compromises the integrity of the timing belt and consequently the timing belt had to be done again (along with the oil seals).
By the way, that is an excellent photo essay you posted, Tiitus.
tiitus
Post by tiitus »
Thanks. :-)
There is lot of more pics coming. :-P
tiitus
Post by tiitus »
Today i take a backseat off and repair it, nothing much, cabel was loose.
very easy to put it back in hole.
Some cleaning and window wash operation too.
And those ugly curtains i take off. :?
tiitus
Post by tiitus »
Now water temperatutre is fine, i also change temperature sensor.
Then i thought about gauges....
I need EGT, turbo boost and maybe water temperature gauges and don`t want put
them on dashboard, then i think, how about this way?
Mayby i made a box where i put those? :? :-)
tiitus
Post by tiitus »
I think this pic is not seen here yet.
Nothing much to do but driving my deli, if next week is warmer outside then
I promise to do something to car. :-)
tiitus
Post by tiitus »
New glowplugs are now in and it`s starting much better.
Yesterday I got a stuck, when driving deep snow :-(
I need a better tires and winch. :?
Or chains....
tiitus
Post by tiitus »
That`s truth, but I`m so lazy :-|
And if you are stuck whit yours stomach, chains don`t help.
Spring is goming fast on here and have to do something my deli.... :?
Now I have to take of backseats, because need my deli on working project.
Some another fixing have to do also... pics later. :-)
tiitus
Post by tiitus »
All day long fixing my deli, new audio system (130W pioneer in back) and
childrens want`s little roof screen. :-)
Do this works?
http://www.youtube.com/watch?v=1_CjW9hDCug
tiitus
Post by tiitus »
You guess what happens now?
Yes! Finally I change the belts and all seals.
Two days a go, alternators tighten bolt severed and I thought why not
do all things at once. :-)
Maybe I take a front of car little bit higher and make leafsprings better too.
But we see what is the results. :?
Return to “Member Rides”
