Given my present paj might be dead'ish and not worth fixing if it's the head I've come across another paj.
A 93 LWB 2.8 which seems reasonably decent. Questions...though.
Is the 93 2.8 when they changed the Injector Pump...front seal issues? Or was that even later?
Rear passenger door 'outside' handle is not working...works from the inside though. Expensive to fix..hard to fix?
Has a sunroof that just barely opens and closes telling me the motor is about done (?) or I'm not sure. How much to fix a sunroof on this thing?
Anything funky about the 93's other than the potential IP front seal issue??
O
93 LWB 2.8 - Advice on buying
- Vehicle: '90 Pajero LWB 2.5 TDi
- LeeHammy
Re: 93 LWB 2.8 - Advice on buying
No idea.. but on a side note if I may.. what are you doing with your old one? There are some minor trim parts I may want to get my hands on if you are parting it out.. Let me know. :)
i like cheese
I've decided not to go with the pajero and pick up a toyota surf 3.0 instead. Good service history, clean, low kms...
As for my paj...I'd rather sell it whole vs slowly stripping it down. In the end for someone that's got the know how it's not a bad fixer-upper. Lord knows I've made sure just about everything - at least everything important is working.
- LeeHammy
I was more talking getting my hands on hub covers and the MMC badge on the back door is all.
i like cheese
Hmm... I can't help with the rim caps stuff as I have after market rims. The back MMC I do have... shoot me an email.
