Just replaced my alternator and voltage is were it should bex but the voltage will change one tenth (.1) of a volt every half second. My engine speed is also rolling. I will change my fuel filter and check my wiring. Anything else it may be?
Regards,
Eric
all lights flicker slighlty at all times
- super7
- Vehicle: MK 1 SWB Pajero turbo diesel
- Big-Bird
- Vehicle: 96 PE8W Spacegear
Re: all lights flicker slighlty at all times
loose connection either at the alternator or the battery. A dirty/corroded battery clamp or cable. Loose ground cable at the engine or body from the battery.
Another item is the alternator could be faulty on the amperage output. A quick charging test at Partsource is free and worth the trip.
