I Have a 1991 JDM spec Pajero which translates into a 1992 U.S. spec Montero.
I have the 4d56T Diesel engine, but need to know if the CV axles from the gasoline Montero will fit the Pajero.
Anyone? Anyone?
Thank you in advance for any help.
BP.
'91 Paj CV Axles
- Vehicle: 1991 JDM Pajero v44
Re: '91 Paj CV Axles
Went here: (through some great advice!) http://www.partsbase.org/mitsubishi/
And it does indeed look like the Gas and Diesel versions share the same axle part numbers.
BP
BP
- PHIL
- Vehicle: 97 PajEvo, 92 Strada, 03 Montero
Excellent info gathering and even more excellent that you shared. As a rule, the 4d56 platform shared with the 3.0 v6 and the 4m40 2800 shared with the 3.5L v6 when it came to anything not directly engine related. I haven't found a case where this wasn't true yet, but it is still a good idea to do your homework.BulletProof wrote:Went here: (through some great advice!) http://www.partsbase.org/mitsubishi/
BP
1997 Pajero Evolution no.581
1992 Strada 4-door pickup
2003 Montero XLS
2003 Montero XLS
- Vehicle: 1994 Pajero V26wg
Hi guys, I am looking at the same problem and would like to know if the NA Montero cv axles worked and how big a job was the re/re?
Thanks in advance...
- PHIL
Hey Bill,mitsubill wrote:Hi guys, I am looking at the same problem and would like to know if the NA Montero cv axles worked and how big a job was the re/re?
All I can quote you is the numbers, which say it's a match as long as you buy for the right truck (as was posted above, add a year on to the North American part when you ask for it - 91 Paj is 92 Montero, etc).
I've done gen 1s and other mitsus so i can give you a few pointers, snice they're very similar... In terms of the install, it's not the end of the world, but it does require a few things moved out of the way. You'll have to pull the brakes (can be left connected to lines), hub flanges (snap-ring pliers help immensely), and then get the knuckle out of the way too. This means separating ballpoints, so you'll need a separator. Finally you can access the cv axles. Slide hammer is really helpful here.
If you've downloaded a copy of the factory service manual, this is well documented for you. I can provide a link if you don't have it...
Hope this helps somewhat.
2003 Montero XLS
2003 Montero XLS
Hey Phil, thanks for quick reply, part numbers match, 91, 2.5 Japanese V44 to 3.0 Montero so I am going to order from Lordco, about 60% of the cost from the speciality dealers... Have a pickle fork to separate the knuckle/ball joints and what is that saying. " the lord hates a coward" so I guess we will see just how difficult it can be..lol
Sent from my iPad using Tapatalk
PS.... Have a Haynes for Pajero, hopefully it will be thorough enough....
- Big-Bird
- Vehicle: 96 PE8W Spacegear
The pickle fork may damage the grease boot on the ball joints. One of the less evasive separation methods is to hit the knuckle itself with a small sledge or heavy ballpean hammer. The shock usually releases the tapered joint faster than the fork method and the hammer method won't damage the grease boot.
Stacey David (Speed Channel) does a short bit on this method in his old GRZ Show.
https://www.youtube.com/watch?v=z_JzIdlolfg
