need a new fuel tank or way to fix mine
Mitsubishi Pickup
strada-caster
Vehicle: Mitsubishi Strada 1992
Post by strada-caster »
For a strada, the l300, l400, and pajero tank is completely different in shape.
I put a pretty good crack (bottom of tank) in my fuel tank due to a tree stump. It's now about one inch long, and will get larger over time just from vibration alone.
So far I've tried 'seal all' with some 'dual color putty' (forgot the name but dries to steel strength stuff) on top, and it looks like in the long run, this will not hold up. I let the seal all dry first. This fix might hold a 1/4 tank pressure but no more.
My question is:
Where have all the veggy conversion and dual tank delicas got their extra fuel tank made?
or
The other alternative is, weld the crack. anybody know anyone with the cohonees to pull that off. It scares the crap out of me, but i'm a major beginner when it comes to welding.
thedjjack
Vehicle: 1989 L300 HITOP!!
Re: need a new fuel tank
Post by thedjjack »
Most radiator shops fix metal fuel tanks....it is easy (they clean them first so no fuel!)
Strada 92
Vehicle: Mitsubishi Delica L400 1995
Re: need a new fuel tank or way to fix mine
Post by Strada 92 »
If you are not able to repair your tank,check for a fuel tank for a Dodge Ram 50 1989 4wd 4cyl. 2.6l. carburetor.
It's direct fit,keep the fuel gauge and the tubing from the Strada.
Wish it will help.
Mitsubishi L400 Spacegear
Mitsubishi I-MiEV 2012
Strada 92
Post by Strada 92 »
Oh,forgot to mention that the Ram 50 need to be simple cab long wheelbase or a sportcab model.It's the big tank.
RichD
Post by RichD »
Diesel tanks are safer to weld than gasoline tanks. You should be able to get this repaired by a certified welder.
Richard Dagenais
Golf Cart
Vehicle: 1992 Exceed
Post by Golf Cart »
Strada,
To stop the crack from getting any longer, drill a hole at both ends of the crack. they can be filled in later - they dont have to be very big,
strada-caster
All excellent info, thanks alot guys.
Not many places fix fuel tanks anymore apparently, but it looks like Townside Automotive in Victoria can do a clean and repair for a decent price.
Return to “Strada”
