A little while ago I was sliding the switch from inside air to outside air and it appeared to have broken, now the switch slides super easy and appears to do nothing. There is noticeably less heat as well and the cab fogs up really bad. I'm just wondering if anyone has run into this problem and solved it. I just want to know as much about it as I can before I tear it all apart.
Thanks!
outside air vent switch broken
- Vehicle: 89 low roof L300
Re: outside air vent switch broken
If you take the glove box out you will have a clear view of the cable that controls the flap. After you take the glove box out move the lever for outside air and you should be able to see where it came off.
Ok great thanks for the reply! I was about to tear the face off the switches so I'm glad you pointed me in the right direction
