Tool for holding the cam sprocket/crank pulley
Posted: Tue Mar 04, 2014 1:03 pm
by DylanQ
I am wondering if anyone has the tool for holding the cam sprocket/ crank pulley while it's getting torqued and would be willing to lend/rent it for a day or two. I'm in Salmon Arm BC. Or if anyone has an idea of something that could be rigged up to work the same?
Dylan
Re: Tool for holding the cam sprocket/crank pulley
Posted: Wed Mar 05, 2014 9:51 am
by lrp374
Canadian Tire in Salmon Arm may loan tools. They do @ several other locations.
Posted: Wed Mar 05, 2014 1:46 pm
by thelazygreenfox
In a pinch you can use a strap wrench to hold the pulley. There is a pic of the proper tool but can't remember where I saw it on this site. Princess auto has a fan belt wrench that tightens or to its self. Use a proper torque wrench and torque to specs.
good luck
TLGF
Posted: Wed Mar 05, 2014 10:04 pm
by thedjjack
I have used an old timing belt to hold the sprocket in the past.... I suspect most timing belts are the same teeth spacing so a garage may have one in the garbage
