CB antenna advice
- patty
- Vehicle: delica chamonix
Re: CB antenna advice
im gonna buy that one for a 100 bucks with the base and PA option.
- Erebus
- Vehicle: 1992 Super Exceed
Sorry, been to busy to log in latelyTardisDeli wrote:Is it true that Loran C antenna are same as marine CB? If so would they work on Delica ?
George ? Green1 ? Ruminante ? Anyone know for sure ?
![Sad :-(](./images/smilies/icon_sad.gif)
CB frequencies are at about the 8th harmonic of the Loran frequencies, so it might just work. As has been said, hook in an SWR meter and see what it shows. BTW, many SWR meters don't do such low frequencies, they only do VHF.
Co-phased antennas only work well when separated by the right distance. The delica is very narrow, so it would probably result in a radiation pattern that is strongly biased to the sides, rather than front/back.ghmorris wrote:If I was putting a CB in a Deli and was looking for performance rather than cool, I'd probably start by looking at a couple of Firesticks, (probably the 4' ones, but maybe just 2') on a pair of mirror mounts with a co-phased harness. It might be safer to go stainless rather than fibreglass for bush use as the fibreglass is going to be more brittle and break easier, not to mention transfer more load to the mounts...George
Keep in mind that mounting an antenna near the back of the Delica with put out a stronger signal to the front, and mounting at the front will bias the signal to the rear. Wikipedia's article is actually pretty good on antennas.
Like so many other aspects of electronics, most of antenna stuff is magic and doesn't really follow the rule book. So, try it and see what happens.
I never thought about the difference in flexibility of steel vs. fibreglass antennas. I've got a 5" fibreglass whip that I intend to mount on the roofrack (it has spring and quick release), so I'll have to be careful. But then I'm used to having to watch my height -- most of my ham antennas aren't very flexible either.
73s de VE6FVD
![Image](http://www3.telus.net/vandriel/Delica/Summit%209600%2020194.jpg)
- Vehicle: 92 Delica, 89 Mercedes 300D
We have a standing joke about the Wireless business around here. 50% science, 50% art and 80% black magic...
George
![Mitsumaple :M](./images/smilies/icon_mitsumaple.gif)
George
- Erebus
That might not be the best route. Depending on how good the coax is, it could pick up interference from the wiring, or it could cause electrical interference. Best to keep coax as far away from power wires as possible.coaxial wrote:For cabling I will just run the ant. cable through the grommet behind the fuse box, same path as my aux headlight wires.
- Erebus
Well, I might be more impressed if your website name and logo gave the name as ChAllenger, not ChEllenger, and you might want to spell "factory" correctly: "Factroy Address:"acmeantenna wrote: Challenger communication equipment Co., Ltd. We specialize in the design and manufacture of Antennae, Antenna Mounts, accessories etc.
Besides, the appropriate location for ads is in the "Parts and supplies" section.
I advise all forum members to stay away from this company.
