How to remove an L300 door panel.
Mbryant
Vehicle: White 93 Exceed Crystal lite roof
Post by Mbryant »
How to remove a door panel. I have more than seven pictures so they are divided over two postings because I read that we can/should only add a max of seven photos to a post.
Mbryant
How to remove a door panel (part two)
Post by Mbryant »
Here is the second part of how to remove a door panel.
On step seven I use a large flat screw driver but there is a specific tool that can be purchased to do the job. The screwdriver worked fine for me.
On step eight I took apart the door light from the back but I had read in another post that an alternative is to remove the light cover and unscrew the light fixture from the panel.
On step nine I tried to put an arrow to the section I was describing but my computer skills maxed out. So I am describing the area where the door panel (gray) meets the plastic piece (black) in the window corner.
Return to “Body General”
