Give me a call directly on 25-954-2157 and I can explain all I know about cold weather preparation and starting issues.
The front pump seal makes a big difference to the starting and running on the 4M40 engines. The replacement takes about 4.5hrs and the seal is only $18.
Thanks, glen
oil filter
- ccautos
- Vehicle: 92 Delica SE
Re: oil filter
The oil filter on the L400 is not the same as on the L300, in fact the L400 filter is HUGE by comparison. (the fuel filter however does appear to be the same on both vehicles)Golf Cart wrote:Oya ,when I mentioned Baldwin BD28 filter, I didnt realize you had an L400, but I think they should be the same since its just displacement that we are talking about- Chime in mechanical Gurus if this is not the case. ( I may decide to get one some day)
*edited to say what I mean instead of what I said....*
- Golf Cart
- Vehicle: 1992 Exceed
Re: oil filter
Green1, I was referring to the oil filter in regards to the original post . I don't have a clue what the L400 uses for a fuel filterGreen1 wrote:The fuel filter on the L400 is not the same as on the L300, in fact the L400 filter is HUGE by comparison. (the fuel filter however does appear to be the same on both vehicles)Golf Cart wrote:Oya ,when I mentioned Baldwin BD28 filter, I didnt realize you had an L400, but I think they should be the same since its just displacement that we are talking about- Chime in mechanical Gurus if this is not the case. ( I may decide to get one some day)
Re: oil filter
Despite what I wrote, I too was refering to the oil filter... the OIL filter is not the same in the L300 and L400, the fuel filter however is.Golf Cart wrote:Green1, I was referring to the oil filter in regards to the original post . I don't have a clue what the L400 uses for a fuel filterGreen1 wrote:The fuel filter on the L400 is not the same as on the L300, in fact the L400 filter is HUGE by comparison. (the fuel filter however does appear to be the same on both vehicles)
- Golf Cart
Re: oil filter
the roundy thing on the engine
Re: oil filter
That be the one! L400: longish roundy thing, L300: shorter roundy thing...Golf Cart wrote:the roundy thing on the engine
- ShaneA
- Member's Photo Album: http://www.delica.ca/Photos/index.php?cat=12984
- Vehicle: '94 Space Gear LWB
Re: oil filter
I think he meant 250-954-2157.ccautos wrote:Give me a call directly on 25-954-2157
Thanks, glen
- ccautos
Re: oil filter
I think he worked it out ..... he already called me but thanks for pointing out my inability to write my own phone number !!!
