Restoration of my delica
Re: Restoration of my delica
Good idea. Maybe do a little cleaning while you are at it... smiles.
How long do you anticipate it will take you to change all the seals and belts?
tiitus
Vehicle: Delica L300
Post by tiitus »
FalcoColumbarius wrote:Good idea. Maybe do a little cleaning while you are at it... smiles.
What I have done these in pajero it takes about 3h, delicas it take a little more
time, seats etc.
I try first time now a payen seals. Seller say "Those are very good", but we will see. :-)
tiitus
Post by tiitus »
FalcoColumbarius wrote:Maybe do a little cleaning while you are at it... smiles.
It's clean enough? :-D
tiitus
Post by tiitus »
Friend and I make some job to done, roof-rack is now on.
It's too high, but not a long time.
tiitus
Post by tiitus »
And we make a short trip to woods, couple pics there:
L300Foca
Vehicle: Mitshubishi L300 2.5 TD GLX
Post by L300Foca »
tiitus wrote:I think this pic is not seen here yet.
Nothing much to do but driving my deli, if next week is warmer outside then
I promise to do something to car. :-)
This one is not seen too :)
FollowMe
L300Foca
Post by L300Foca »
tiitus wrote:I but here some story, when I try to fix my car.
First, there was a some engine warm up problem, so I change
thermostat, piece of cake.
Which thermostat opening temperature (C) is fabric ? Please
FollowMe
4D56 Thermostat:
Valve opening temperature of thermostat in Centigrade: 82 + 1.5
Full-opening temperature of thermostat in Centigrade: 95
Valve lift mm: 8.5 or more.
Check this out: L-300 A/C & Cooling systems
P.S.: Not sure what you mean by "fabric" in this instance.
L300Foca
Post by L300Foca »
FalcoColumbarius wrote:4D56 Thermostat:
TNX!!
Fabric = New engine from factory
Why I ask this? Becouse, in Bosnia i can find couple thermostats whith diferent opening temperatures.
So, 82 writed on the bootom of thermostat is that one? Original?
FollowMe
L300Foca wrote:Why I ask this? Becouse, in Bosnia i can find couple thermostats whith diferent opening temperatures.
Read the manual I posted a link to. It speaks of different thermostats for the different engines that have powered the L300. The engine you are writing about is the 4D56T?
Tiitus, nice articulation on your wagon's suspension.
L300Foca
Post by L300Foca »
Its 4D56T engine (82 deg), and I found that in manual, tnx!
FollowMe
tiitus wrote:It's clean enough? :-D
Very 8-)
tiitus
Post by tiitus »
Like I write another toopic, I use 88c thermostat, when is -25 outside car is not
getting enough warm inside if you use coulder thermostat.
Also my pajero (same engine) manual give this:
!WRONG!Thermostat valve opening temperature C°(F°) 88(190)!WRONG!
Here is right one: http://www.mitsubishi4wd.com/delica/muut/thermostat.jpg
tiitus
Post by tiitus »
Thank you. :-)
I think it's need some act, like a get it 5cm higher.
Front is easy, but back leafs need more job.
L300Foca
Post by L300Foca »
Most of time i drive on summer, so 82 works 4 me :)
FollowMe
Return to “Member Rides”
